OpenSSL certs
Sep 12th, 2010
  • Cisco Employee,
Had a recent install with Veisign certs thats was fun.
Therefore looking at some questions before I deploy the openssl cert for guest access.
Reading the docs it says the following
"Ensure that the host name that is used to create the certificate (Common Name) matches the Domain Name System (DNS) host name entry for the virtual interface IP on the WLC and that the name exists in the DNS as well"
However IF we use 1.1.1.1 as the usual virtual interface IP address and asscociate this with the CName in DNS it would publish this, now I am not a DNS expert but recall you can have an internal/external lookup so it woiuld be on the internal lookup?
Also in the Verisign product page it does not list the Cisco WLC as server type for SSL certs. Which should I go for?
Any help appreciated
George Stefanick Wed, 09/22/2010 - 21:39
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Pete, did you get this taken care of buddy? Do you still need a hand?
Trending Topics - Security & Network
