Commands for ASA
Answered Question
Sep 12th, 2010
What is the command to clear the screen?
After typing the "show run" command, the screen will display many lines.  If I do not want to continue to see the rest of the config, how do I get out of the "show run" command.
Thanks.
Debra
Correct Answer by Nagaraja Thanthry about 6 years 10 months ago
There is no ASA specific command to clear the screen. You need to use the
commands supported by the terminal program for it.
NT
Type "q" to break out of the current command output.
NT
Overall Rating: 5 (2 ratings)
Correct Answer
Nagaraja Thanthry Sun, 09/12/2010 - 19:17
  • Cisco Employee,
NT
debra-brown Sun, 09/12/2010 - 19:35
Thanks NT.  What is the command to clear the screen?  I typed CLS and nothing happens.
Thanks.
Correct Answer
Nagaraja Thanthry Sun, 09/12/2010 - 20:05
  • Cisco Employee,
NT
