David Hornstein Sun, 09/12/2010 - 21:21
  • Gold, 750 points or more
Hi Albert,
The WVC210 is a webcam with it's own computer and webserver built in.  It is not designed and cannot be used  for skype or webex.
The WVC210 allows you to remotely or locally use the camera to monitor the environment/ office or whatever.  It can also be used in conjunction with a PC to record on motion detection.
So basically the WVC210, like it's other family members such as PVC2300, WVC2300, PVC300  are  surveillance cameras. That can be used with or without our free surveillance application.  The WVC210 and other members of the surveillance family can be used to populate our free surveillance application to capture one or multiple cameras at once.  See a screen capture below.  If you want a camera for skype of webex check out logitech.
regards Dave
