bargerjc8 Tue, 09/14/2010 - 14:28
As far as Cisco is concerned, there is no time limit.  You can take the CCNA at any time.  If you have a voucher from the course you took, you might want to check with them if there is an expiration date to the voucher.
When you pass the CCNA, it renews all other 642-xxx exams that you currently hold.  For example, if you have a current CCENT and then pass the CCNA, both exams would be good for 3 more years from the date you pass the CCNA.
