Disabling a WIC-3G?
Sep 12th, 2010
Hi all.
A number of my remote sites have been converted from wireless wan links (via HWIC-3G-GSM cards) to wired wan links. The 3G WICs are still in the routers and due to their remoteness are likely to stay there. I've removed all the wireless configuration that I can find:
interface Cellular0/0/0
no ip address
encapsulation ppp
shutdown
line 0/0/0
exec-timeout 0 0
no exec
Router#sh cellular 0/0/0 profile
* - Default profile
However the logs keep filling up with these messages:
Sep 13 14:35:08 AEST: %CELLWAN-2-MODEM_DOWN: Cellular0/0/0 modem is DOWN
Sep 13 14:35:22 AEST: %CELLWAN-2-MODEM_UP: Cellular0/0/0 modem is now UP
Sep 13 14:36:06 AEST: %CELLWAN-2-MODEM_DOWN: Cellular0/0/0 modem is DOWN
Sep 13 14:36:20 AEST: %CELLWAN-2-MODEM_UP: Cellular0/0/0 modem is now UP
Sep 13 14:37:04 AEST: %CELLWAN-2-MODEM_DOWN: Cellular0/0/0 modem is DOWN
What else do I need to do to disable the 3G WICs? Thanks.
heathrw Sun, 09/12/2010 - 23:12
  • Bronze, 100 points or more
Can you send the full configuration to see what else might be in there.
ashkentapa Mon, 09/13/2010 - 16:32
version 12.4
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname ROUTER
boot-start-marker
warm-reboot
boot-end-marker
logging message-counter syslog
logging buffered 131072
enable secret 5 xxxxxx
aaa new-model
aaa authentication login default group tacacs+ group radius line
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ group radius if-authenticated
aaa session-id common
clock timezone AEST 10
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.x.x.1 10.x.x.99
ip dhcp excluded-address 10.y.y.1 10.y.y.99
ip dhcp pool Pool1
   network 10.x.x.0 255.255.255.0
   default-router 10.x.x.1
   dns-server 10.z.z.114 10.z.z.62
   domain-name company.com
   lease 7
ip dhcp pool Pool2
   network 10.y.y.0 255.255.255.0
   default-router 10.14y.y.1
   domain-name companu.com
   lease 7
ip cef
no ip domain lookup
ip domain name company.com
key chain EIGRPKeyChain
key 1
   key-string 7 xxxxx
username admin secret 5 xxxx
archive
log config
  hidekeys
ip tcp path-mtu-discovery
ip tftp source-interface FastEthernet0/0.100
interface Loopback0
ip address 192.168.200.189 255.255.255.255
description Corporate LAN trunk
no ip address
ip flow ingress
duplex auto
speed auto
description Office VLAN
encapsulation dot1Q 10
ip address 10.x.x.1 255.255.255.0
ip helper-address 10.z.z.62
ip flow ingress
encapsulation dot1Q 100
ip address 10.y.y.1 255.255.255.0
ip flow ingress
interface FastEthernet0/1
description WAN link (512 kbps)
ip address 10.a.a.26 255.255.254.0
ip authentication mode eigrp 130 md5
ip authentication key-chain eigrp 130 EIGRPKeyChain
speed 100
full-duplex
no ip address
encapsulation ppp
shutdown
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
router eigrp 130
passive-interface default
no passive-interface FastEthernet0/1
network 0.0.0.0
no auto-summary
eigrp stub connected summary
neighbor 10.a.a.12 FastEthernet0/1
neighbor 10.a.a.11 FastEthernet0/1
neighbor 10.a.a.2 FastEthernet0/1
neighbor 10.a.a.1 FastEthernet0/1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-cache timeout inactive 10
ip flow-cache timeout active 5
ip flow-export version 5
ip tacacs source-interface Loopback0
ip radius source-interface Loopback0
logging trap debugging
logging 10.a.a.102
logging 10.a.a.67
access-list 8 remark SNMP & RSH access
access-list 8 permit 10.a.0.0 0.0.15.255
access-list 8 permit 10.b.0.0 0.0.15.255
snmp-server community xxxx RO 8
tacacs-server host 10.a.a.93 key 7 xxxx
tacacs-server host 10.a.a.59 key 7 xxxx
tacacs-server directed-request
radius-server host 10.a.a.139 auth-port 1645 acct-port 1646 key 7 xxxx
control-plane
banner login ^C
THIS IS A PRIVATE COMPUTER SYSTEM --- USAGE MAY BE
MONITORED AND UNAUTHORIZED ACCESS OR USE MAY RESULT
IN CRIMINAL OR CIVIL PROSECUTION
^C
line con 0
location xxxx
exec-timeout 60 0
password 7 xxxx
line aux 0
line 0/0/0
exec-timeout 0 0
no exec
line vty 0 4
location xxxx
exec-timeout 60 0
password 7 xxxx
line vty 5 15
location xxxx
exec-timeout 60 0
password 7 xxxx
scheduler allocate 20000 1000
ntp server 10.a.a.93
end
ashkentapa Mon, 09/13/2010 - 16:18
Hi Ashok.
Thanks for your suggestions. I've already tried deleting the modem profile but it didn't stop the errors. As you can see from the output below there are no remaining cellular profiles:
ROUTER#sh cellular 0/0/0 profile
* - Default profile
ROUTER#
I've tried to turn off the radio but I can't access the controller in order to run the command. I can do a "sh controller" on it:
ROUTER#show controllers cellular 0/0/0
Interface Cellular0/0/0
HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz unit 0,
HWIC cellular modem configuration:
etc...
But I can't enter controller configuration mode:
ROUTER(config)#con?
config-register  configuration  connect  control-plane
ROUTER(config)#
So I can't actually run the "gsm radio off" command. The routers are 1841s with wic-3g-gsm WICs in them. There must be some other method for accessing the cellular controller on these boxes. I'll keep looking. Thanks.
james.mirtsis Mon, 09/13/2010 - 17:16
Sometimes the commands are hidden, have you tried typing the full command regardless of whether it shows up on the help?
ROUTER(config)#controller cellular 0
also do a show priv, you will need to be priv 15. The only other way to shut it down is to remove it from the chasis.
ashkentapa Mon, 09/13/2010 - 17:22
Hi James.
Thanks for your response. I am indeed running at privilege level 15:
ROUTER#sh priv
Current privilege level is 15
Yet the "controller" command is not available:
% Invalid input detected at '^' marker.
I think I'm just going to have to get used to seeing those errors in the logs
