13041 TACACS+ authentication request switches from Login to Change Password functionality.
Sep 12th, 2010
Hi Team,
I am not able to change password on ACS clients in next log on.
on ACS 5.1 getting below message.
Even i selected "Changed Password on Next Login"
ACS Logs given..
Status:
Failed
Failure Reason:
Logged At:
Sep 13, 2010 9:48 AM
ACS Time:
ACS Instance:
ACS-PRI
Authentication Result
Type=Authentication
Authen-Reply-Status=Fail
Server-Msg=As per GSD setting telnet not used for TML CEP devices.
Steps
Received TACACS+ Authentication START Request
Evaluating Service Selection Policy
Matched rule
Selected Access Service - Default Device Admin
Evaluating Identity Policy
Matched Default Rule
Selected Identity Store -
Current Identity Store does not support the authentication method; Skipping it.
TACACS+ will use the password prompt from global TACACS+ configuration.
Returned TACACS+ Authentication Reply
Received TACACS+ Authentication CONTINUE Request
Using previously selected Access Service
TACACS+ ASCII change password request.
Milind Rane
Waris Hussain Mon, 09/13/2010 - 11:43
Hi ,
Are you using  ACS5.0 is yes then there is feature limitation on that code, this feature is supported in ACS 5.1
Here is the feature request : CSCtc31598
Symptom:
The "user must change password on next login" feature for TACACS+ authentication for users defined in the local ACS store does not work.
If set, users will fail to login
Workaround:
none
Waris Hussain.
