Does the 'phone service SPA525G-http-write Yes' option work?
Sep 12th, 2010
I see that under telephony-service you can add the config 'phone service SPA525G-http-write yes' which adds xml to the SPA525Default.cnf.xml file to set this setting.  Does anyone have any ideas if this setup is working yet?  I've just loaded a SPA525G phone with 7-4-6 load but it's not setting that option correctly atm when I do a full reset and let it load settings from the UC520 box.
I know there was mention in the tech doc covering the disabling of the web server that this centralised setting config may not yet be supported on the SPA525G's but I can't access the bug ID referenced by the document as it apparently contains confidential info.
Anyone used the 'phone service' options successfully for the SPA handsets (SPA515G in particular).
