LMS 3.2 configuration backup
Sep 13th, 2010
I want to take the backup  of all the devices in my network using lms 3.2 . Can somebody tell me the procedure for the same. Need help step by step.
Abhijit
Joe Clarke Mon, 09/13/2010 - 16:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Go to RME > Config Mgmt > Archive Mgmt > Sync Archive.  Select All Devices, then run the job.  This assumes you have added proper credentials (typically SNMP read-write and telnet/SSH usernames and passwords) under Common Services > Device and Credentials > Device Management.
anigudkar Tue, 09/14/2010 - 00:55
Hi Josef,
Thanks for your reply. Now I have added the devices as per the procedure given by you. I just want to know where will this configuration will get stored.
Please tell me the path so that I can start taking backup of all the devices.
Abhijit Nigudkar
Joe Clarke Tue, 09/14/2010 - 16:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The configs are archived under NMSROOT/files/rme/dcma.  The internal archive is found in the devfiles directory, where as the user-consumable files can be found in the shadow directory.
