Does a CISCO2811-SRST/K9 come with a firewall
Answered Question
Sep 13th, 2010
Hi All,
I have an CISCO2811-SRST/K9 ordered , but will need to know if it has a firewall with this bundle.
I will need to setup a VPN from this device to a head office and runn a Call Manager SIP trunk over the VPN.
Thanks very much for any help
Alalli
Correct Answer by ashok_boin about 6 years 10 months ago
This is just a voice bundle and you will get basic Cisco IOS security feature set.
You need to opt for C2811-VSEC/K9 if you want both voice and security.
Pls refer the following link...
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd804e773d.html
Regards...
-Ashok.
Overall Rating: 5 (1 ratings)
alalli Mon, 09/13/2010 - 04:04
Hi Ashok
Thanks so much.
I think I am going to need the following IOS for this implementation.
By the way,  what do you get with the standard security features on the other version of IOS please?
Amanda
C2811-VSEC-SRST/K9
2811 VSEC Bundle with PVDM2-16, FL-SRST-36, Adv IP Serv, 128F/256D
ashok_boin Mon, 09/13/2010 - 22:09
  • Bronze, 100 points or more
Hi Amanda,
Please find the following link (CCO login required) to check about supported security features. This is Cisco tool (Feature Navigator) which gives you to look the supported features in detail.
tools.cisco.com/ITDIT/ISTMAIN/servlet/index
And, pls check the following link to get an idea about the differences between Cisco IOS releases.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin09186a00801af451.html
Regards...
-Ashok.
