VLAN filtering with mac
Sep 13th, 2010
I'm trying to filter a mac address on a vlan using VACL/VLAN access map but i can't get it working om my 4510R. None of the traffic from the host seems to be filtered.
I want to filter mac 001c.7ec8.e7b2 on vlan 11. Here's the configuration:
mac access-list extended abcdef
permit host 001c.7ec8.e7b2 any
vlan access-map block1 10
action drop
match mac address abcdef
vlan access-map block1 20
action forward
vlan filter block1 vlan-list 11
When i use this exact same config on a 3560 it works just fine.
When i use a ip acl instead of a mac acl the filtering for that particular ip address works
What could be te case? The ios ver of the 4515R is 12.2(53)SG.
thanks
Jon Marshall Thu, 09/23/2010 - 10:54
Dennis
Just a guess but could you reorder your first entry ie.
action drop
to
action drop
Jon
DennisV99_2 Thu, 09/23/2010 - 11:45
Hi Jon,
Allthough i did configure the match line before the action line it shows up the lines the other way around in de running-config. Strange huh?
Nevertheless the show vlan access-map command shows the correct config:
Vlan access-map "block1"  10
  Match clauses:
    mac address: abcdef
  Action:
    drop
Vlan access-map "block1"  20
  Match clauses:
  Action:
    forward
