VLAN4 goes down for 1 or 2 minute then it automatically goes up
Sep 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hi ,
I have 2 site one is IPPL(core switch) and  2nd one is IPGCL .IPGCL is connect to IPPL by trunk port. Under IPGCL i have 16 L2 switch that are used ring tropology with IPGCL. (A (PPCL)--------> B (IPGCL) --> C --> D ----> ……..      --> B). A are the primary swicthes at 2 sites,  Vlan 1 is the native Vlan and  all switches is part of VLAN1 but another 13 VLAN is assign on switch port. now the problem is some time VLAN4 goes down for 1 or 2 minute then it automatically goes up.i have tryed lot of time to find out
Can anybody help me on this.
Arup
Bobby Thekkekandam Mon, 09/13/2010 - 11:27
  • Cisco Employee,
Hi Arup,
When VLAN4 is down, are there any access ports that are members of VLAN 4 that are up/up OR
is there at least one trunk port that carries VLAN4 that is up/up?
-Bobby
