Guest Sessions report won't work
Sep 13th, 2010
Hi All,
When I run a guest sessions report in WCS I get the following:
The specified criteria did not match any data for the report.
Make sure that the following background tasks are running:
1.Guest Sessions
The above background task is running and all of the other reports work ok too. Any suggestions?
I'm running WCS 7.0.164.0 and WLC 7.0.98.0 - I did have some problems with the Guest sessions report before I upgraded.
Many Thanks
Scott
scottwilliamson Thu, 12/09/2010 - 00:22
None at all I'm afraid. Seems no-one out there has an answer to this problem.
Scott
Surendra BG Thu, 12/09/2010 - 00:55
Hi Scott,
Are we selecting the profile manually??(Report By = EDIT)
Surendra
scottwilliamson Thu, 12/09/2010 - 01:30
Hi Surendra,
It makes no difference whether I select a profile or just leave it as default (ie all users), I get the same result.
Scott
Sebastian Helmer Thu, 12/09/2010 - 07:45
Hey,
I give the system a last change ;) and started the report once again...
Login Time was 8:15 of the Guest test user.
at16:41 I got a report with the result I aspected.
what did until now:
I just refresh the config of the controller in te WCS and  I added a new AP but nothing more.
Very strange but not really a solution, maybe the time but my guest session background task runs every 15min.
I just want to update with my information. I don't believe that it helps but i will monitor it now and if I got any news I will inform you.
- Sebastian
scheu@cisco Wed, 12/22/2010 - 06:32
there is a bug regarding this problem:     CSCtj22801
The workaround is not really working for us, because we want to schedule this report.
Hopefully it will be fixed in the next release...
regards,
Michael
Related Content
Trending Topics - Security & Network
