09-13-2010 03:21 AM - edited 03-06-2019 12:56 PM
I am trying to recover password for cisco 2950 Switch after reboot i am able log in switch but while reset the password i am trying to entered in global configuration mode and type conf t commend iam getting "% Authorization failed." Message.
Kindly find below for command and for error Message.
system software:
flash_init
load_helper
boot
switch: flash_init
Initializing Flash...
flashfs[0]: 374 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4766208
flashfs[0]: Bytes available: 2975232
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
switch: load_helper
switch: dir flash
unable to stat flash/: permission denied
switch: rename flash:config.text flash:config.old
switch: boot
AFTER BOOT THE SWITCH
Switch>en
Switch#rename flash:config.old flash:config.text
Destination filename [config.
Switch#copy flash:config.text system:running:config
Destination filename [running:config]?
%Error opening system:running:config (Is a directory)
Switch#copy flash:config.text system:running-config
Destination filename [running-config]?
14222 bytes copied in 6.624 secs (2147 bytes/sec)
HBUATS2#
*Mar 1 05:36:30: %LINK-3-UPDOWN: Interface Vlan2, changed state to up
*Mar 1 05:36:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan2, changed
state to down
HBUATS2#configure terminal
HBUATS2#
Here I am not able to entered in Global Configuration Mode,
Kindly suggest.
Thanx.
09-13-2010 05:22 AM
Most likely you have configured AAA command authorization and the switch is
not able to communicate with the AAA server. Please perform password
recovery procedure and then remove the corresponding AAA configurations.
Once you check and make sure that the AAA server is working correctly (if
you are intending to use AAA command authorization), put the AAA commands
back in there.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_reco
very09186a0080094184.shtml
Hope this helps.
NT
09-14-2010 12:41 AM
Thanx for your reply,
Already I went through link which u send to me and found the issue.
Just gothrough my first blog where u will find all that instruction which suggested on this link for password recovery.
Thanx.
