WAP4410N: Repeat more than one SSID
Sep 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I bought several WAP4410N Access Points.
One is used as an Access Point with two SSIDs.
I want the other ones to work as repeaters for these SSIDs.
Each time I use the option "Allow wireless signal to be repeated by a repeater.", the second SSID gets disabled automatically.
Is there a way to configure the access points to repeat more than one SSID?
Thanks in advance.
