Whatsnew Command
Answered Question
Sep 13th, 2010
Hello All,
I come to now a new command that "whatsnew" which helps to know what recent changes made on device. i tried on our one of device but did find the command in help. than i tried to find this in Command Lookup Tool but i did not find such command. My college how told me about this used many time in his previous Orangization. I also check on google and found folowing URL which shows such a command exists.
http://www.nil.com/ipcorner/RouterConfigMgmt/
Can any one guide me where i can find more information about this?
Jagdev
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
There is no such command as "whatsnew". If you notice, in the document, they
created an alias for a different command and named it as "whatsnew"
"so I decided to make an alias for it with the alias exec whatsnew show
archive config differences nvram:startup-config system:running-config
configuration command."
I am assuming even your colleague might have set it up similarly. To see
what has changed, you need to use " show archive config differences
nvram:startup-config system:running-config" command.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Mon, 09/13/2010 - 05:40
  • Cisco Employee,
Hope this helps.
NT
