Mar 11th, 2009
      i have VIC2-2FXS installed on C2801.
the first port is not working.
the second is not working.i replaced the VIC but problem still exsists.
ext,2628 works / ext,2627 not work.
attached debug output.
Paolo Bevilacqua Wed, 03/11/2009 - 08:32
How many wires are used in the cable that goes from port 1 to telephone? Please make sure that only two are present.
Nicholas Matthews Wed, 03/11/2009 - 19:44
If you switch the device in the first port to the second port do you get the same result?
ibrahim_hassan Thu, 03/12/2009 - 06:27
Yes, also i configured another extension such as 2629 but also the same problem exsists.
