Cisco vpn client unable to get certificate
hyeh Tue, 09/14/2010 - 11:36
Hi Jesper
You need to open a DOS prompt, and change the directory to where the QuickVPN is installed
1: Click cmd.exe from C:\Windows\System32
2: cd "C:\Program Files (x86)\Cisco Small Business\QuickVPN Client"
Use the openssl.exe program (contained in that directory) to get the certificate from your
SA500 and save it into a file called "cert.pem"
> openssl.exe s_client -showcerts -connect x.x.x.x:443 > cert.pem
NOTE: where "x.x.x.x" is the WAN IP address of your SA500
hyeh Tue, 09/14/2010 - 11:44
Or, you can just download the certificate from your SA500 directly.
Click the "Download" button in Administration->Authentication->Download Router Certificate
Save the certificate in your  QuickVPN directory with the name cert.pem
