anyconnect and Active Directory
Sep 13th, 2010
Had anyone done a anyconnect and active directory setup. Still a little lost. I got the vpn working fine with ldap and staff can login fine. My next task is to get them to get there drive mappings. What would be the easiest or most common way of doing this.
ARMANDO ALVARADO Tue, 09/14/2010 - 05:33
I read that anyconnect version 2.4 and above does support this or is this incorrect from cisco..
Jason Gervia Tue, 09/14/2010 - 05:41
Anyconnect scripting supports starts in AC 2.4 and above.  there should also be examples (one of them does drive mapping) on the anyconnect download site.
BARRY GROSS Mon, 09/13/2010 - 11:45
I have an anyconnect profile setup using SBL that logs into my directory just as if it were onsite. if you own the machines this is the method I would go.
ARMANDO ALVARADO Tue, 09/14/2010 - 05:32
Thank You Berry I will talk with our system adminstrators and possbile check this avenue out.
