Cisco 2911 - Remote Access VPN
jschrody1
I have a 2911 Router that I am trying to configure for remote VPN access.
I have tried three different clients, with varying results (none of them successful).
Using the Cisco VPN Client version 5:
Cisco Systems VPN Client Version 5.0.00.0320
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      09:44:17.011  09/13/10  Sev=Info/6 GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
2      09:44:21.027  09/13/10  Sev=Info/4 CM/0x63100002
Begin connection process
3      09:44:21.292  09/13/10  Sev=Info/4 CM/0x63100004
Establish secure connection
4      09:44:21.292  09/13/10  Sev=Info/4 CM/0x63100024
Attempt connection with server "74.124.21.40"
5      09:44:22.027  09/13/10  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with xx.xx.21.40.
6      09:44:22.105  09/13/10  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to xx.xx.21.40
7      09:44:22.120  09/13/10  Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
8      09:44:22.120  09/13/10  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
9      09:44:22.120  09/13/10  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = xx.xx.21.40
10     09:44:22.120  09/13/10  Sev=Warning/2 IKE/0xE300009B
Invalid SPI size (PayloadNotify:116)
11     09:44:22.136  09/13/10  Sev=Info/4 IKE/0xE30000A6
Invalid payload: Stated payload length, 568, is not sufficient for Notification:(PayloadList:149)
12     09:44:22.136  09/13/10  Sev=Warning/3 IKE/0xA3000058
Received malformed message or negotiation no longer active (message id: 0x00000000)
...and on the 2911...
*Sep 13 14:44:26.822: ISAKMP:(0):Checking ISAKMP transform 11 against priority 1 policy
*Sep 13 14:44:26.822: ISAKMP:      encryption 3DES-CBC
*Sep 13 14:44:26.822: ISAKMP:      hash SHA
*Sep 13 14:44:26.822: ISAKMP:      default group 2
*Sep 13 14:44:26.822: ISAKMP:      auth pre-share
*Sep 13 14:44:26.822: ISAKMP:      life type in seconds
*Sep 13 14:44:26.822: ISAKMP:      life duration (VPI) of  0x0 0x20 0xC4 0x9B
*Sep 13 14:44:26.822: ISAKMP:(0):Preshared authentication offered but does not match policy!
*Sep 13 14:44:26.822: ISAKMP:(0):atts are not acceptable. Next payload is 3
Using Windows XP Networking:
2911 Router:
*Sep 13 14:51:28.674: ISAKMP:(0):Checking ISAKMP transform 2 against priority 1 policy
*Sep 13 14:51:28.674: ISAKMP:      encryption 3DES-CBC
*Sep 13 14:51:28.674: ISAKMP:      hash SHA
*Sep 13 14:51:28.674: ISAKMP:      default group 2
*Sep 13 14:51:28.674: ISAKMP:      auth pre-share
*Sep 13 14:51:28.674: ISAKMP:      life type in seconds
*Sep 13 14:51:28.674: ISAKMP:      life duration (VPI) of  0x0 0x0 0x70 0x80
*Sep 13 14:51:28.674: ISAKMP:(0):atts are acceptable. Next payload is 3
*Sep 13 14:51:28.674: ISAKMP:(0):Acceptable atts:actual life: 0
*Sep 13 14:51:28.674: ISAKMP:(0):Acceptable atts:life: 0
*Sep 13 14:51:28.674: ISAKMP:(0):Fill atts in sa vpi_length:4
*Sep 13 14:51:28.674: ISAKMP:(0):Fill atts in sa life_in_seconds:28800
*Sep 13 14:51:28.674: ISAKMP:(0):Returning Actual lifetime: 28800
*Sep 13 14:51:28.674: ISAKMP:(0)::Started lifetime timer: 28800.
*Sep 13 14:51:28.674: ISAKMP:(0): processing vendor id payload
*Sep 13 14:51:28.674: ISAKMP:(0): processing IKE frag vendor id payload
*Sep 13 14:51:28.674: ISAKMP:(0):Support for IKE Fragmentation not enabled
*Sep 13 14:51:28.674: ISAKMP:(0): vendor ID seems Unity/DPD but major 194 mismatch
*Sep 13 14:51:28.674: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
*Sep 13 14:51:28.674: ISAKMP:(0): vendor ID is NAT-T v2
*Sep 13 14:51:28.674: ISAKMP:(0): vendor ID seems Unity/DPD but major 184 mismatch
*Sep 13 14:51:28.674: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Sep 13 14:51:28.678: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM1
*Sep 13 14:51:28.678: ISAKMP:(0): constructed NAT-T vendor-02 ID
*Sep 13 14:51:28.678: ISAKMP:(0): sending packet to 71.244.0.152 my_port 500 peer_port 500 (R) MM_SA_SETUP
*Sep 13 14:51:28.678: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Sep 13 14:51:28.678: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Sep 13 14:51:28.678: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM2
*Sep 13 14:51:28.854: ISAKMP (0): received packet from 71.244.0.152 dport 500 sport 500 Global (R) MM_SA_SETUP
*Sep 13 14:51:28.854: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Sep 13 14:51:28.854: ISAKMP:(0):Old State = IKE_R_MM2  New State = IKE_R_MM3
*Sep 13 14:51:28.854: ISAKMP:(0): processing KE payload. message ID = 0
*Sep 13 14:51:28.874: ISAKMP:(0): processing NONCE payload. message ID = 0
*Sep 13 14:51:28.874: ISAKMP:(0):found peer pre-shared key matching 71.244.0.152
*Sep 13 14:51:28.874: ISAKMP:received payload type 20
*Sep 13 14:51:28.874: ISAKMP (1028): His hash no match - this node outside NAT
Using Windows 7 Networking:
*Sep 13 14:55:30.638: ISAKMP:(1029):Checking IPSec proposal 2
*Sep 13 14:55:30.638: ISAKMP: transform 1, ESP_3DES
*Sep 13 14:55:30.638: ISAKMP:   attributes in transform:
*Sep 13 14:55:30.638: ISAKMP:      encaps is 4 (Transport-UDP)
*Sep 13 14:55:30.638: ISAKMP:      authenticator is HMAC-SHA
*Sep 13 14:55:30.638: ISAKMP:      SA life type in seconds
*Sep 13 14:55:30.638: ISAKMP:      SA life duration (VPI) of  0x0 0x0 0xE 0x10
*Sep 13 14:55:30.638: ISAKMP:      SA life type in kilobytes
*Sep 13 14:55:30.638: ISAKMP:      SA life duration (VPI) of  0x0 0x3 0xD0 0x90
*Sep 13 14:55:30.638: ISAKMP:(1029):atts are acceptable.
*Sep 13 14:55:30.638: IPSEC(validate_proposal_request): proposal part #1
*Sep 13 14:55:30.638: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= 74.124.21.40, remote= 71.244.0.152,
    local_proxy= xx.xx.21.40/255.255.255.255/17/1701 (type=1),
    remote_proxy= 71.244.0.152/255.255.255.255/17/1701 (type=1),
    protocol= ESP, transform= NONE  (Transport-UDP),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
*Sep 13 14:55:30.638: IPSEC(ipsec_process_proposal): invalid transform proposal flags -- 0x800
*Sep 13 14:55:30.638: ISAKMP:(1029): IPSec policy invalidated proposal with error 1024
Here is a subset of the config:
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
ip dhcp excluded-address 192.168.3.1 192.168.3.100
ip dhcp excluded-address 192.168.3.151 192.168.3.254
username syspro privilege 15 secret 5 $1$jGd5$kz8Y2djeC3rem.Sfe0Vgv1
username jschrody privilege 15 secret 5 $1$f/RG$j274n/.bzQIgO8ensNLKn/
crypto ctcp port 10000
crypto logging ezvpn
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key XxXxXxXxXx address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 60 20
crypto isakmp nat keepalive 60
crypto isakmp xauth timeout 30
crypto isakmp client configuration group DevelopmentVPN
key XxXxXxXxXx
dns 8.8.8.8
pool SDM_POOL_1
group-lock
save-password
max-users 50
max-logins 2
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group DevelopmentVPN
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto dynamic-map vpn-map 1
reverse-route
crypto map vpn-map client authentication list ciscocp_vpn_group_ml_1
crypto map vpn-map isakmp authorization list ciscocp_vpn_group_ml_1
crypto map vpn-map client configuration address respond
crypto map vpn-map 10 ipsec-isakmp dynamic vpn-map
interface Loopback40
ip address xx.xx.21.40 255.255.255.255
ip nat outside
ip virtual-reassembly
crypto map vpn-map
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$
ip address xx.xx.20.46 255.255.255.252
ip nat outside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.3
description $ETH-LAN$
encapsulation dot1Q 103
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2.4
encapsulation dot1Q 104
ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/2.5
encapsulation dot1Q 105
ip address 192.168.5.1 255.255.255.0
interface Virtual-Template1 type tunnel
ip unnumbered GigabitEthernet0/2.3
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
ip local pool SDM_POOL_1 192.168.3.151 192.168.3.200
ip default-gateway xx.xx.20.45
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool InternetAccess xx.xx.21.41 xx.xx.21.41 netmask 255.255.255.248
ip nat inside source route-map SDM_RMAP_1 pool InternetAccess
ip route 0.0.0.0 0.0.0.0 xx.xx.20.45
access-list 141 remark CCP_ACL Category=18
access-list 141 permit ip 192.168.3.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 141
Any ideas where I'm going wrong?
I haven't look at it in detail but it seems that you're trying to connect with your VPN client using a pre-shared key and the router is configured for authentication using certificates.
This is your phase 1 configuration:
encr 3des
group 2
The default value as far as I remember is rsa signatures for the authentication.
You can try the following:
authen pre-share
Federico.
encr 3des
group 2
isn't 'authen pre-share' just a shortened version of the same command?
Just to clarify the overall WAN architecture...
We currently have 2 sites, with connectivity from different service providers.
The local IPs for the first site are 192.168.1.0/24
The local IPs for the second site are 192.168.2.0/24
This router will have an inside interface supporting 192.168.3.0/24
We eventually want to provision three VPN items.
An always up tunnel to/from site 1
An always up tunnel to/from site 2
VPN server for remote clients to attach to 192.168.3.0/24, and be able then to access all three subnets.
I was starting with the VPN server, with int Gi0/1 being the service provider (outside) interface, and Loopback40 being the IP clients would hit.
Unfortunately, each of the different VPN clients I try to connect with get different results, none of which are successful.
At this point I'd be happy to get any one of the clients working properly.
You're right about the authentication (i missed that sorry).
You're using isakmp profiles, why not use regular IPsec Site-to-Site and RA configuration?
In this way you create a dynamic crypto map for the VPN clients and bind it to the static crypto map used by the site-to-site connections.
Federico.
