Clients are Deauthenticated, Authenticated, Associated all the time
Sep 13th, 2010
i'm using WLC 2112 with the soft. version 6.0.199.0
I'm recevind i the logs a huge amount of traps that clients are Deauthenticated, Authenticated, Associated
I monitoring all logs, and there is no log about the coverage hole or other waring info that should do this re-authentication
This events happening almost periodically.
Problem is that some of them are loosing connection to the AP
i removed all timeouts
Thanks for any info
Surendra BG Thu, 09/16/2010 - 23:40
  • Cisco Employee,
is there any specific time interval that the clients lose connectivity? like every 10 minutes or like that?
Surendra
peter_jevos Fri, 09/17/2010 - 01:46
Than you for your answer
no it isn't . Sometimes  is 2hors, sometimes 30 minutes and son
I allowed to sent all traps, and my log is filled only with this Deauthenticated, Authenticated, Associated messages.
So there is noreason like interference, coverage hole and so on
First message is :
Client Deauthenticated: MACAddress:7c:6d::ef Base Radio  MAC:58:b7:70 Slot: 1 User Name: XXX Ip Address: XX.XX.XX.XX Reason:Unspecified  ReasonCode: 1
then follows Client Association, Client Authenticated and so on
thanks
peter_jevos Mon, 09/20/2010 - 06:34
No they are not roaming.
I have checked all snmp traps and all  i get is those authentication , association stuff
however during this annoncments the clietns are disconnecting
thanks
Surendra BG Mon, 09/20/2010 - 08:18
  • Cisco Employee,
How many APs are there in the location? are we facing interference?? like.. the signal overlap is very high??
Surendra
peter_jevos Tue, 09/21/2010 - 00:08
dear surendra
thank you for your answer
There are 5 AP's for the 50 40 people in the openspace, so it's really covered
There are no coverage holes or any interferences ( at least SNMP traps show nothing )
thank you
pet
