CAD 7.6.1 - receive error upon launch.
Answered Question
Sep 13th, 2010
Installed CAD 7.6.1.  Receiving pop-up error:  "Unable to download file.  Could not open request".  At this point, I can select the "ok" button, and the load continues successfully.   Looking at the logs, I am seeing the following information:
09/13/10 11:31:58.056  3452  agent  Thd(2276)  CNetPort(01986350)::InitializeSecureSockets(), failed to open the ctios client
  registry key [Software\Cisco Systems, Inc.\CTI OS Client]
09/13/10 11:31:58.072  3452  agent  Thd(2276)  CSSLRSA::ReadPEMKeyFile(), error:02001002:system library:fopen:No such file or
  directory
09/13/10 11:31:58.072  3452  agent  Thd(2276)  CSSLRSA::DecryptData(), EVP Key is NULL! error:20074002:BIO
  routines:FILE_CTRL:system lib
I am stuck.  We are trying to get this error window to go away, and unfortunately, I've run into a wall.   Any suggestions or help?
Many thanks in advance!
Cheri
Correct Answer by Aaron Harrison about 6 years 5 months ago
Do you have a proxy configured in IE? I often see this when CAD can't understand the proxy config; most often this is when a proxy auto-config script is used rather than a simple proxy address and bypass list.
If so try disabling the proxy and restarting CAD.
Aaron
Please rate helpful posts..
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Tue, 09/14/2010 - 00:26
Aaron
cherilynn1030 Tue, 09/14/2010 - 05:51
The client had a proxy on!   This fixed my error!
Thank you SO very much!!!
Cher
geoff@hp.com Tue, 09/14/2010 - 06:24
Because the client will probably want to use the proxy, turn off automatic updates using PostInstall.exe on the server.
Geoff
Amit Sharma Tue, 03/17/2015 - 03:18
i alos faced same issue and after remove the proxy setting still my cad agent is showing failed option to downlaod updates...\\what can i do for it?
i already reinstall CAD application! but still same error...
Related Content
