clicking and disconnects with PRI
sdwitner1
I am running a cisco 2851 as a voice gateway and am getting more intermittent outbound calls that disconnect when the remote party answers. sometimes we hear a clicking noise right before the disconnect. I have checked my T1 controller and it is showing no slips or errors. Any ideas???
15 Replies 15
byrne
Would be good to verify that you have the network-clock-paricipate and the network-clock-select command in the configuration.
Is this PRI going to a PSTN carrier? (have you checked with them?).
I have the network-clock-participate in the configuration. This PRI is between the 2851 and a Comdial phone system.
Foster2851#sh network-clocks
Network Clock Configuration
Is the clock source line or internal for this PRI?
Looks like the output show network-clocks was not complete, do you see a priority 1 Clock Source? Is it this PRI?
The clock source is internal
Priority Clock Source Clock State Clock Type
10 Backplane GOOD PLL
Current Primary Clock Source
controller T1 1/0
framing esf
clock source internal
linecode b8zs
pri-group timeslots 1-24
description PBX slot
Do you a T1 coming from a PSTN provider connected to this gateway?
Yes...see below. I have 3 T1's configured as an MLPPP group.
interface Multilink1
description MPLS-FRO2004147191VRP
ip address 1.2.3.4 255.255.255.252
ip route-cache flow
no peer neighbor-route
no cdp enable
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
max-reserved-bandwidth 100
service-policy output QOS-SCHEDULER-MU1
interface Serial0/0/0
no ip address
encapsulation ppp
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1/0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/2/0
no ip address
encapsulation ppp
ppp multilink
Foster2851#sh controller t1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: PBX slot
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20090408, FPGA: 255, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Current port master clock:recovered from backplane
Data in current interval (812 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 6 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
I see this voice t1 is in a Network Module (controller T1 1/0), is it using DSP resources from the Network Module or the mother board(show diag) and "voice-card" configuration.
Do you have a voice T1 going to the telco?
If you are using dsp resources from the mother board and the t1 in on a network module this t1 would have to participate in in the tdm backplane clocking domain.
voice-card 0
dspfarm
dsp service dspfarm
no local-bypass
voice-card 1
no dspfarm
Slot 0:
PVDM Slot 0:
        48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8540-05
        Board Revision           : C0
        Deviation Number         : 0
        Fab Version              : 04
        PCB Serial Number        : FOC13513LV5
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-48
        Version Identifier       : V01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 ED 41 04 00 82 49 21 5C 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 35 31
          0x20: 33 4C 56 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 34 38 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
PVDM Slot 0:
        Part Number              : 73-8848-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC13520A6Z
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-8
          0x00: 04 FF 40 04 30 41 04 00 82 49 22 90 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 35 32
          0x20: 30 41 36 5A 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 38 20 89 56 30 31 20 D9 02
Looks like the show diag was not complete, I do not see Network Module Slot 1.
Is it possible to give complte show diag and the "network-clock participate" and "network-clock select" commands?
Foster2851#sh diag
Slot 0:
C2851 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC134855MF
Hardware Revision : 1.0
Top Assy. Part Number : 800-26922-04
Board Revision : E0
Fab Version : 03
RMA History : 00
Processor type : 87
Hardware date code : 20091130
Chassis Serial Number : FTX1402AK47
Chassis MAC Address : c47d.4f05.8580
MAC Address block size : 32
CLEI Code : COMV510ARA
Product (FRU) Number : CISCO2851
Part Number : 73-8480-05
Version Identifier : V05
0x00: 04 FF C1 8B 46 4F 43 31 33 34 38 35 35 4D 46 40
0x10: 03 E9 41 01 00 C0 46 03 20 00 69 2A 04 42 45 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 90 FA C2 8B 46 54 58 31 34 30 32
0x40: 41 4B 34 37 C3 06 C4 7D 4F 05 85 80 43 00 20 C6
0x50: 8A 43 4F 4D 56 35 31 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 35 31 20 20 20 20 20 20 82 49 21 20
0x70: 05 89 56 30 35 20 D9 03 40 C1 C2 FF FF FF FF FF
PVDM Slot 0:
Board Revision : C0
Fab Version : 04
RMA History : 00
Processor type : 00
WIC Slot 0:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC13424HSX
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 33 34
0x10: 32 34 48 53 58 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
PCB Serial Number : FOC13424HSR
Board Revision : A0
RMA History : 00
0x10: 32 34 48 53 52 82 49 20 9A 05 42 41 30 03 00 81
WIC Slot 2:
FT1 PMC4351
PCB Serial Number : FOC13424JA5
Board Revision : A0
RMA History : 00
0x10: 32 34 4A 41 35 82 49 20 9A 05 42 41 30 03 00 81
WIC Slot 3:
FXS Voice daughter card (4 port)
Hardware Revision : 3.1
Part Number : 73-6918-02
Board Revision : G0
Fab Version : 02
PCB Serial Number : FOC14026PQT
RMA History : 00
Top Assy. Part Number : 800-17016-02
Connector Type : 01
CLEI Code : IP9IABYCAA
Product (FRU) Number : VIC-4FXS/DID=
0x00: 04 FF 40 00 3A 41 03 01 82 49 1B 06 02 42 47 30
0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 34 30 32
0x20: 36 50 51 54 03 00 81 00 00 00 00 04 00 C0 46 03
0x30: 20 00 42 78 02 05 01 C6 8A 49 50 39 49 41 42 59
0x40: 43 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
High Density Voice NM-HDV2-1T1/E1 Port adapter
Hardware Revision : 1.1
Top Assy. Part Number : 800-22167-05
Board Revision : D0
Fab Version : 05
PCB Serial Number : FOC14062U26
RMA History : 00
Fab Part Number : 28-6126-05
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Product (FRU) Number : NM-HDV2-1T1/E1
0x00: 04 FF 40 03 DA 41 01 01 C0 46 03 20 00 56 97 05
0x10: 42 44 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
0x20: 34 30 36 32 55 32 36 03 00 81 00 00 00 00 04 00
0x30: 85 1C 17 EE 05 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 48 44
0x50: 56 32 2D 31 54 31 2F 45 31 89 56 30 35 20 D9 02
0x60: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FPGA revision:0x16C
WIC Slot 0:
Board Revision : G0
Fab Version : 02
PCB Serial Number : FOC14026PQN
RMA History : 00
Connector Type : 01
0x20: 36 50 51 4E 03 00 81 00 00 00 00 04 00 C0 46 03
WIC Slot 1:
HDV2 on board t1/e1 controller (1 port)
PVDM Slot 0:
Board Revision : C0
Fab Version : 04
RMA History : 00
Processor type : 00
