09-13-2010 10:58 AM - edited 03-06-2019 12:56 PM
I am having an issue where I am adding a catalyst switch to my ACS server for AAA authentication.
I have a catalyst with the following:
inteface vlan 174
ip address 192.168.174.1
interface vlan 199
ip address 192.168.199.1
When I setup the switch in the ACS, the ACS rejects it because it sees the traffic coming from a different SVI 2. I would like to set it up on SVI 174. My question is, how do I make the traffic source out of SVI 174?
Josh
Solved! Go to Solution.
09-13-2010 11:26 AM
Can you try "ip tacacs source-interface "vlan id"" and see if that helps?
NT
09-13-2010 11:26 AM
NT
09-13-2010 12:23 PM
That worked. Thanks a lot!
