TACACS+ and Local Authentication Simultaneously
Sep 13th, 2010
Is there any way that authentication can be configured to use TACACS+ and local authentication simultaneously.  For example, most users will have user profiles and will be authenticated using a TACACS server, but a few accounts will be configured locally on the Cisco device.  I have used the following two configurations:
aaa authentication login default group tacacs+ local
(This configuration only goes to the local database if communication with the TACACS server fails completely)
aaa authentication login default local group tacacs+
(This configuration only checks the local database and never goes to the TACACS server)
I have not been able to find a configuration that will use TACACS and local authentication simultaneously
Panos Kampanakis Mon, 09/13/2010 - 11:34
  • Cisco Employee,
You cannot do what you are trying to do. For (default login you need to use the first policy matched.
you can diversify telnet/ssh with http by  creating different aaa groups.
But still you will be loging in for telnet users (all of them) using one method.
I hope it is clear.
PK
