WebVPN on IOS and Client Side Certificate-Based Authentication
nunovaz
Hi there,
I have successfully configured WebVPN using client side certificate-based authentication and AAA. But when i use the username-prefill command, I always get "login" as the username. How can I configure the IOS to get the UPN from the certificate?
Thanks.
Nuno Vaz
5 Replies 5
Todd Pula
Level 7
Level 7
What version of code are you testing with?
I'm using IOS Version 15.0(1)M3
nunovaz
I upgraded the IOS to version 15.0(1)M3 and the problem remains the same.
After choosing the certificate to use, in the WebVpn login page the username field is lock and empty. I enter the password for the user in the certificate and get this debug:
*Nov 14 16:48:51.183: CRYPTO_PKI: Adding peer certificate
*Nov 14 16:48:51.187: CRYPTO_PKI: Check for identical certs
*Nov 14 16:48:51.187: CRYPTO_PKI: Create a list of suitable trustpoints
*Nov 14 16:48:51.187: CRYPTO_PKI: Suitable trustpoints are: ************,
*Nov 14 16:48:51.187: CRYPTO_PKI: Attempting to validate certificate using ***************
*Nov 14 16:48:51.203: CRYPTO_PKI: Certificate is verified
*Nov 14 16:48:51.203: CRYPTO_PKI: Checking certificate revocation
*Nov 14 16:48:51.215: CRYPTO_PKI: Certificate validation succeeded PASSING appctx is [0x***************
*Nov 14 16:49:05.711: AAA/AUTHEN/LOGIN (00000000): Pick method list '***************'
*Nov 14 16:49:05.711: WV-AAA: AAA authentication request sent for user: "Login"
*Nov 14 16:49:07.715: WV-AAA: AAA Authentication Failed!AAA authentication request sent for user: "Login"
The username of the user isn't "Login". Where is the IOS getting this value from?
In Cisco ASA there is a command that allows you to choose the certificate field to be used as username. Is any command for this on IOS ?
Can anybody help me ?
Thanks in advance.
I have the same issue if I use together these both commands "authentication certificate aaa" and "username-prefill"
I run IOS version 15.1(3)T1
Btw, Certificate-Only Authentication and Authorization Mode also doesn't work, because the router can't take "cert_username" from a certificate. It always appear as empty in debug:
002542: Jun 30 03:32:01.622 MSK: WV: validated_tp :  cert_username :  matched_ctx :
002543: Jun 30 03:32:01.622 MSK: WV: Received appinfo
validated_tp : corpca, matched_ctx : ,cert_username :
002544: Jun 30 03:32:01.622 MSK: WV: Trustpoint match successful
002545: Jun 30 03:32:01.622 MSK: WV: Extracted username:  pass: ?
Anybody has working client certificate authentication on IOS routers?
You can add configuration like  "authorization username subjectname commonname" for the trustpoint used for authenticating client cert.
