What is the reset sequence on a 7961?
Answered Question
Sep 13th, 2010
What is the reset sequence on a 7961?  This is for just a reset, not a reset to factory defaults, just reset the phone?  Thanks.
Correct Answer by dksingh about 6 years 10 months ago
Assuming SCCP/Skinny load on the 7961, would suggest to go to Network Config via phone menu
first and then try entering **#**
Overall Rating: 4 (2 ratings)
Rob Huffman Mon, 09/13/2010 - 12:31
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anthony,
Press Settings Button then **#**
Cheers!
Rob
d.anthony.hadley_2 Mon, 09/13/2010 - 12:39
Thanks Rob, I did that sequence but it just doesn't reset the phone.  There may be something else going on then.
   Anthony
Correct Answer
dksingh Mon, 09/13/2010 - 12:44
  • Cisco Employee,
d.anthony.hadley_2 Mon, 09/13/2010 - 12:51
Yes, that did it.  I went to the Network Configuration and did the sequence, it reset.  Thanks.
brendand05 Mon, 09/13/2010 - 17:40
Setting > **#** works, you just need to press the digits quickly
