Answered Question
Sep 13th, 2010
Hi all,
I have a doubt about disk replacement in NME-WAE, when I have a problem with the disk and I have to put a new one: how I make to install the waas OS in the new disk?
Thanks for your help,
Correct Answer by Bhavin Yadav about 6 years 1 month ago
Hi Guzman,
Here you go...
Start from:
To reinstall the system software on an NME-WAE network module installed in a Cisco access router, follow these steps:
Hope this helps.
PS: Please mark this Answered, if this answers your question.
Overall Rating: 5 (1 ratings)
guzman.barrio Mon, 09/13/2010 - 14:16
Thanks for your help Bhavin, I read about this procedure but I want to be sure before proceed.  This is only useful if I don't have problems with the Flash, isn't it?
If I have problems with the FLASH or the files there, I have to use the .sysimg image, isn't it?
Thanks again,
Bhavin Yadav Mon, 09/13/2010 - 14:19
Yes, .sysimg will be useful for flash only but .bin also contains the flash image as well.
