Bridging two sites connected via ethernet
Sep 13th, 2010
I need to span a vlan 100 across 2 sites connected via ethernet. I am thing about using BVI.
Both sites are sharing different VLANs. How I can use BVI for this solution and not brake other connection for other VLANs ?
New vlan is 200
Old VLANs :  vlan 100 -- 10.10.10.100.1
                    vlan  50      10.10.50.1
                    vlan  10      10.10.10.1
                                               int fa0/0  10.10.12.1        int fa 0/0
                                 SITE 1 <---------------------------------------------------------------------------------- -------------   > SITE 2   (  vlan 100, vlan 50,  10, 5 )
                                   | fa0/1 10.20.1.1                                  E T H E R N ET
                              switch
How I should configure BVI in this design ?
Laurent Aubert Mon, 09/13/2010 - 21:58
  • Cisco Employee,
I don't think BVI is the solution as an interface can belong to only one bridge-domain. If you want to keep your L3 subnet between both sites and propagate VLAN at the same time, you should upgrade your routers at both sites to a model which support switching and routing features. The idea is to make your WAN link a trunk.s
You could also terminate your ethernet link on a L2 switch so your WAN becomes a trunk and you connect your router to it so their L3 subnet will be on a dedicated VLAN.
Laurent.
smailbouabdallah Tue, 09/14/2010 - 09:12
Thanks for the reply.
I have a Cisco 3825 router on onesite A  and a 6500 switch on site B .
The sites are connected via ethernet . I need to span a vlan with few users on site B and one user on site A.
I have an ethernet interface connecting the sites and on router site A , I have 3 other interfaces :
ethernet connecting from A to B
one connecting to backup site
another connecting to voice vlan
Other interface connecting to local switch
Any help regarding how to use this BVI ? Thanks,
