ACE - How would you read this output?
Sep 13th, 2010
  I´d like to fully understand the output from show resource usage all.
  Here you have the resource allocation for a context.
resource-class  IEco
   limit-resource all minimum 20.00 maximum unlimited
And here there is the outcome under heavy load. Clearly there has been a resource exhaustion.
The "Min" value follows the resource-class, and in this case, the "Max" pretty much follows the "Min", but why do we have a "Max" since the upper limit is actually unlimited? Please note an upper limit of 325M for bandwidth and depletion took place at roughly 252M
  Regarding the conc-connections resource. Can it be upgraded? As far as I understand only bandwidth, throughput and SSL termination are upgradable.
Is conc-connections a consecuence of bandwidth? How many concurrent connections does an ACE with 8Gbps license have?
Lastly, is there a consideration when it comes to reading the active connections on ACE? A firewall infront of ACE and the servers behing it both report around 1/3 connections of what ACE does.
The version is A2.1(3)
Thanks a lot!
Overall Rating: 4 (1 ratings)
Gilles Dufour Mon, 09/13/2010 - 23:34
pretty simple actually.
Let's assume you have 3 contexts and assign a min of 20% to all of them with max unlimited.
What is the max bandwidth you can get for a single context do you think ?  100% ???
Since all context have 20% min, it means the max for a single context is 100% - (2 x 20) = 60%.
Then assume one context uses 20 + 30 = 50% of the resource.
The other 2 contexts have 20% min....but how much can they get if needed ???
100 - 50 - 20 = 30%
It's not an easy task to play with virtualisation.
ggalteroo Wed, 09/15/2010 - 07:48
Thanks, Giles!
Last question.
Does a 8Gbps license mean 8M concurrent connections? The output suggests it since the aggregate adds up to 8M. The license doesn´t explicitly states connections upgrades and I don´t have a 4Gbps ACE around to play with. If that is the case, would it be the same for a 16Gbps?
Thanks again!
