ACS 4.2.1 JAVA requirement questions
Per Cisco 4.2.1 installation guide, the JAVA requirement is:
Java Run-time Environment (JRE)
Sun JRE 1.4.2_04
Sun JRE 1.4.2_16
Sun JRE 5.0 Update 13
Sun JRE 6.0 Update 3
But our company's security requirement is:
5.0 update 20
6.0 update 15.
My question are:
- What will be the impact if I have JAVA 5.0 update 20  / 6.0 update 15  installed  ( will it affect the ACS running )
Hello Angela
It will not affect anything on working on ACS server. The doc says that it should have minimum JRE version.
My suggestion will be that you should have atleast minimum version installed i.e. Sun JRE 1.4.2_04 and later upgrade to latest one. I have installed the latest java version in my lab and it is running fine.
Let me know if the above reply answered your queries.
thanks
Shree
