Cisco Ironport management interface IP configuration?
Sep 13th, 2010
For configuring the management interface IP for Cisco Ironport device, should it be on the public IP address or private IP address? Could you please confirm the IP address desing for the ironport management interface? thanks
Christopher Smith Tue, 09/14/2010 - 05:43
Greetings Aman,
The answer to this question depends on several factors, what you intend to do with the appliance, how you intend on allowing access to the appliance and where it sits in your network. Typically customers will utilize the management interface on their internal network thus giving it a private IP. This way the web interface, ssh and ftp access are allowed internally but not to the public.  Those services can be enabled on other interfaces as well, but the most common practice is to set up the management interface for internal access only on your private network.
Christopher C Smith
Cisco IronPort Customer Support
