VoIP on iPhone and Blackberry?
Answered Question
Sep 13th, 2010
Is it possible to register an iPhone or Blackberry as an IP Phone on the CCME(Router) 2800 or 2900? Such that when I enter my office premises I should be able to get an extension number exclusively on my iPhone or blackberry via WIFI as we get on any other IP Phone and I should be able to call any desk phone in my office on their extention number and also reach out to PSTN via my Office PRI number.
What are the pre-requisites that I need to take care of? Is this really possible on 2811 or 2921 router which is acting as a CME?
Correct Answer by Justin Brenton about 6 years 7 months ago
Hi There,
While this is not supported by Cisco this doesn't mean that it won't work.  I would suggest configuring this and testing within your environment for yourself for a while before placing in production.  Anything can be implemented with the proper planning.
HTH, Please rate if so
Justin
Overall Rating: 5 (2 ratings)
brendand05 Mon, 09/13/2010 - 17:36
The iPhone client only works with the full CallManager not Express
I would expect that Cisco may release a CME compatible iPhone client in  the next 12 months if they want to keep up with market demand.
Justin Brenton Mon, 09/13/2010 - 20:50
  • Silver, 250 points or more
Hi there,
You can connect from the iphone/bb through a sip client,  create an EZVPN config on the CME. If  you need assistance with that download the cisco configuration  Profesional it has a very good template that will help you configure it.
Fring is a Sip client that you could look into, there are many out there.
You can also see this page where it has a configuration example
http://uc500.com/iphone-sipphone-client-working-cisco-ucme
Justin
paveltoleon Tue, 09/14/2010 - 02:15
Justin,
this solution I'm afraid doesn't let to have all functionality of CME, especially extention number of the desktop phone.
The key question was how to use mobile client of iPhone and BlackBerry to connect to CME using secured connection via 3G or Wi-Fi.
As far as I'm aware there is now solution to integrate BlackBerry phones with CME 8.1 only (beside CM 6.1 or later), but in requires to have BlackBerry Enterprise Server running as well.
http://docs.blackberry.com/en/admin/deliverables/17712/index.jsp?name=for+Cisco+Unified+Communications+Manager+Express+-+Configuration+Guide+-+BlackBerry+Mobile+Voice+System+-+5.0&language=English&userType=2&category=BlackBerry+MVS
To my mind, so far there is one good solution to have mobility function on CME is to use Nokia E-series phone with Nokia Call Connect for Cisco client.
Pavel
Talha Ansari Tue, 09/14/2010 - 03:38
Cant we use a sip client software for iphone and blackberry?
One guy in the link that Justin provided has posted that he is sucessful in registering iphone on 2811... i dont know how reliable that is..
paveltoleon Tue, 09/14/2010 - 04:40
Well, I cannot comment on that as never experienced it myself. If you will look into supported solutions choises are limited. Cisco supports iPhone and BlackBerry only with CM, targeted to large number corporate of users.
Take a look at this:
http://www.ciscosystems.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/714860.pdf
"Research In Motion BlackBerry Enterprise Server version 4.1.6 with BlackBerry MVS Small Business version 1.1 using SIP to Cisco Unified Communications Manager Express Release 7.0."
Correct Answer
Justin Brenton Tue, 09/14/2010 - 07:35
Hi There,
Justin
paveltoleon Tue, 09/14/2010 - 23:45
Justin,
no doubt, proper planning is key to success.
Do you have any experience of deploying Nokia E-series phones on CME?
Pavel
Justin Brenton Wed, 09/15/2010 - 07:44
I haven't implemented any BB sip clients but I have for the Iphone and Android with success.
I used iSip for my install which worked great on the iPhone.
Justin
