Cisco 3660 Router Fast Ethernet problem
Sep 13th, 2010
Dear Experts,
I have cisco 3660 Router which is having some issue, It was working in production and suddendly hang and then when i rebooted Fast Ethenet ports are not working.......
when i start router it gives below error.....
cisco c3660 (R527x) processor (revision C0) with 28672K/4096K bytes of memory.
Processor board ID JAB0445C0ZP
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
3660 Chassis type: ENTERPRISE
4 Serial network interface(s)
24 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
interface FastEthernet0/1
% Invalid input detected at '^' marker.
no ip address
% Incomplete command.
shutdown
duplex auto
speed auto
SETUP: new interface FastEthernet0/1 placed in "shutdown" state
Press RETURN to get started!
You can see it does not show my FE ports even but when i run show ip interface brief
Router# sh ip int bh   ri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  administratively down down
FastEthernet0/1            unassigned      YES unset administratively down down
Serial1/0                  unassigned      YES NVRAM  down                  down
Serial1/1                  unassigned      YES NVRAM  administratively down down
Serial1/2                  unassigned      YES NVRAM  administratively down down
Serial1/3                  unassigned      YES NVRAM  administratively down down
Serial2/0                  unassigned      YES NVRAM  administratively down down
Serial2/1                  unassigned      YES NVRAM  administratively down down
Serial2/2                  unassigned      YES NVRAM  administratively down down
Serial2/3                  unassigned      YES NVRAM  administratively down down
Serial2/4                  unassigned      YES NVRAM  administratively down down
         Serial2/5                  unassigned      YES NVRAM  administratively down down
Serial2/6                  unassigned      YES NVRAM  administratively down down
Serial2/7                  unassigned      YES NVRAM  administratively down down
Serial3/0                  unassigned      YES NVRAM  administratively down down
Serial3/1                  unassigned      YES NVRAM  administratively down down
Serial3/2                  unassigned      YES NVRAM  administratively down down
Serial3/3                  unassigned      YES NVRAM  administratively down down
Serial3/4                  unassigned      YES NVRAM  administratively down down
Serial3/5                  unassigned      YES NVRAM  administratively down down
Serial3/6                  unassigned      YES NVRAM  administratively down down
Serial3/7                  unassigned      YES NVRAM  administratively down down
Serial4/0                  unassigned      YES NVRAM  administratively down down
Serial4/1                  unassigned      YES NVRAM  administratively down down
Serial4/2                  unassigned      YES NVRAM  administratively down down
Serial4/3                  unassigned      YES NVRAM  administratively down down
Serial4/4                  unassigned      YES NVRAM  administratively down down
Serial4/5                  unassigned      YES NVRAM  administratively down down
Serial4/6                  unassigned      YES NVRAM  administratively down down
Serial4/7                  unassigned      YES NVRAM  administratively down down
Router#
Kindly find the Show Tech-support output.....
Bhargav Desai
jorge.calvo Mon, 09/13/2010 - 23:51
  • Bronze, 100 points or more
According from below messages from your show tech, it looks like the router failed due to a hardware error on the FastEthernet por adapter and after the reboot, it was shut down by the router because no ports were found on it.
00:00:05: %AMDP2_FE-1-INITFAIL:  CSR0=0x0000
00:00:05: %AMDP2_FE-1-DISCOVER: Only found 0 interfaces on bay 0, shutting down bay
00:00:05: %PA-3-DEACTIVATED: port adapter in bay [0] powered off.
00:00:05: %AMDP2_FE-1-INITFAIL:  CSR1=0x0000
I would suggest reseating the FastEthernet module and if it does not work, it will need to be replaced.
Hope this helps.
