09-13-2010 11:34 PM - edited 03-03-2019 06:03 AM
I tried to install a new ios, but the boot process was interrupted:
Boot:
Loading "flash:/c3750-ipservicesk9-mz.122-55.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@.....@
Error loading "flash:/c3750-ipservicesk9-mz.122-55.SE.bin"
#verify flash:/c3750-ipservicesk9-mz.122-55.SE.bin
Verified flash:/c3750-ipservicesk9-mz.122-55.SE.bin
#sho boot
BOOT path-list : flash:/c3750-ipservicesk9-mz.122-55.SE.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
#sho flash:
Directory of flash:/
2 -rwx 1618 Mar 1 1993 01:19:32 +01:00 config.text
3 drwx 192 Mar 1 1993 01:08:06 +01:00 c3750-ipservices-mz.122-35
.SE5
507 -rwx 1048 Mar 1 1993 01:19:32 +01:00 multiple-fs
508 -rwx 556 Mar 1 1993 01:00:44 +01:00 vlan.dat
510 -rwx 5472256 Mar 1 1993 01:11:50 +01:00 c3750-ipservicesk9-mz.122-
52.SE.bin
511 -rwx 57 Mar 1 1993 01:19:32 +01:00 private-config.text
15998976 bytes total (13824 bytes free)
is it possible, that there is not enought space?
What happends if i delete the old file ( c3750-ipservices-mz.122-35.SE5) and it won't work?
Can i restore this file in the "debug" modus?
Thanks for your help.
with friendly greetings,
Manuel
Solved! Go to Solution.
09-13-2010 11:42 PM
Firstly, you'll need to delete the old IOS using the command "delete /f /r flash:c3750-ipservices-mz.122-35.SE5".
Next, if this is a one-and-only switch then you can copy the IOS into this switch using the command "archive download-sw tftp://
Hope this helps and don't forget to rate our useful posts. Thanks.
09-13-2010 11:42 PM
09-13-2010 11:53 PM
Thanks for your fast answer.
But im not 100% sure if it works.
Because i haven't got a Tar file, only the bin file.
I will add the boot ios with the command Boot system flash
What can i do if the switch can't boot?
How can i restore the old ios in the worst case?
09-14-2010 12:24 AM
If that's the case, copy the .bin file using the command "copy tftp: flash:".
