3G connect with Failover
Sep 13th, 2010
Hi2All
SP is proposing Wireless WAN for backup connectivity for existing Wired connection, i.e 3G connect for branch office connectivity. Recommended router is 1841. Can I get configuration assistance for 3G to act as failover for primary link. 3G connection would be over public network and need to establish ipsec gre tunnel. OSPF is dynamic routing protocol
best wishes
Anthony
ashok_boin Tue, 09/14/2010 - 02:01
  • Bronze, 100 points or more
You require generic backup interface configuration with "backup commands" on the Cellular interface.
Pls refer the config guide below.
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html#wp1237405
The above link gives backup DDR for Cellular interface as primary. But the same approach you can follow to configure the cellular as backup to a primary interface.
Hope it helps...
Regards...
-Ashok.
