How to do BC-MC and MC-BC using 2 MLS?
Sep 14th, 2010
If a broadcast needs to be forwarded from vlan 10 to vlan 20, and vlans are configured as end to end vlan, how should I configure the ip multicast helper map ?
If one broadcast source is located at vlan 10 and at MLS 1, the conversion point should be at int vlan 10 right?
int vlan 10
ip pim dense-mode
ip directed-broadcast
ip multicast helper-map broadcast mcxlate
ip access-list extended mcxlate
permit udp host any eq 65000
ip forward-protocol udp 65000
So if all broadcast recipients are at vlan 20? Which point should the multicast be converted to broadcast and flood vlan 20?
