Call Waiting in 7931
Sep 14th, 2010
Hello
I am using CUCM 6.1 with two types of  phone 7931 and 7911.I want when any one call to  a particular extension say A is calling to B,and B is already busy with another call with C,then B should see that A is calling and A should get the busy tone.
If i make Busy trigger  1 and  Maximum numbers of call  calls 2  then the calling party is getting the busy tone but but the called party didn't get any information that a call is on wait and if i make Busy trigger 2 and maximum numbers of call 2,then called party getting the information that a call is on wait but the calling party doesn't get the busy tone.
So is there any way simultaneously both the things will occur.
Thanks.
Joseph Martini Sat, 09/18/2010 - 16:29
  • Cisco Employee,
There's no call waiting tone with IP phones on call manager.  If A phone calls another and it's busy the call will either go to voice mail or the caller will get a busy tone.  There's no way for call manager to check if a phone is on another call, still present the call and let the calling phone know the called phone is busy by playing a busy tone.  The best thing to do is to change the busy trigger to something other than one so the called phone will see the other call even when they're on the phone.  However the calling phone will have to wait for the call forward no answer (CFNA) to send them to voicemail.  This is like many cell phones, if you call a phone that's already on another call, the called phone will hear a a beep letting the called phone know there is another call coming in, but the calling phone will still ring as usual until eventually the call goes to voicemail.  The problem here is that either the call is delivered (the calling phone hears ring back) or the call is not delivered (doesn't ring the called phone) and the caller hears a busy tone.
