Cisco Security Agent installation on Cisco AQM
Sep 8th, 2010
  • Bronze, 100 points or more
While installing Cisco Security Agent (CSA) I getting a warning messege. Please check the attachment. we are using AQM for UCCX.
My question is "will CSA going to work properly if I click yes and continue with the installation.
Aaron Harrison Thu, 09/09/2010 - 00:55
  • Community Spotlight Award,
    Member's Choice, May 2015
I would expect that it would not work well; I've not tried it though. It's for UCCX and the other listed products.
I've also never seen any defects (well, that I can remember) in the release notes referring to AQM, and since AQM is written by Calabrio and CSA by Cisco, you can guarantee they would have dropped the ball at some point.
Aaron
Please rate helpful posts...
Hossain Ahmed A... Thu, 09/09/2010 - 01:15
Thanks Aaron, I also think it should work properly as calabrio is certified by cisco.
Ashfaque.
Aaron Harrison Thu, 09/09/2010 - 01:49
No no, you misunderstand me - I say it will probably NOT work.
Hossain Ahmed A... Thu, 09/09/2010 - 01:57
Thanks for correcting I missed the 'not' from your 1st line....
Ashfaque
