TCL scripted probes on ACE
Sep 14th, 2010
I have two questions about TCP scripts on ACE :
1. TCP source code
How can I browse the TCL source code of predefined probe scripts on the ACE (for instance HTTPCONTENT_PROBE) '
2. Script parameters
How do I retrieve in the TCL script the parameters passed to the script in the command < script script_name [script_arguments] >  ?
Thank you,
Yves
Gilles Dufour Tue, 09/14/2010 - 04:33
  • Cisco Employee,
Yves,
you can download all the scripts from the download software page.
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=A2%283.2%29&mdfid=280557289&sftType=Application+Control+Software+Scripts&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+ACE+Application+Control+Engine+Module&treeMdfId=268437639&treeName=Application+Networking+Services&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
# Copyright (c) 2005-2008 by Cisco Systems, Inc.
# debug procedure
# set the EXIT_MSG environment variable to help debug
# also print the debug message when debug flag is on
proc set_exit_msg { msg } {
    global debug ip port EXIT_MSG
    set EXIT_MSG $msg
    if { [ info exists ip ] && [ info exists port ] } {
        set EXIT_MSG "[ info script ]:$ip:$port: $EXIT_MSG "
    if { [ info exists debug ] && $debug } {
        puts $EXIT_MSG
# main
# Parse cmd line args and initialize variables
set_exit_msg "initializing variable"
if { $argc <  2 } {
    set_exit_msg "[ info script ] parameters :
    exit 30002
set ip $scriptprobe_env(realIP)
set port $scriptprobe_env(realPort)
# If port is zero then use well known HTTP port 80
if { $port == 0} {
    set port 80
set requestHeader [ lindex $argv 0 ]
set expectFileType [ lindex $argv 1 ]
set debug [ lindex $argv 2 ]
if { $debug == "" } {
    set debug 0
# Open connection
set_exit_msg "opening socket"
set sock [ socket $ip $port ]
# Send HTTP request to server
set_exit_msg "sending request : $requestHeader"
puts -nonewline $sock "$requestHeader\n\n"
flush $sock
# Read string back from server
set_exit_msg "receiving response"
set lines [ read $sock ]
# Close connection
set_exit_msg "closing socket"
close $sock
# Parse the HTTP response
# All the following conditions cause probe failure, returning exit code 30002
# Unable to recognize the HTTP response
if { ![ regexp -nocase "^HTTP/1\.\[0-9\] (\[0-9\]\[0-9\]\[0-9\])" $lines match s
tatuscode ] } {
    set_exit_msg "probe fail : can't find status code"
    exit 30002
# HTTP response is not 200 OK
if { $statuscode != "200" } {
    set_exit_msg "probe fail : status code is $statuscode"
    exit 30002
# Unable to find Content-type header
if { ![ regexp  -nocase  "Content-Type *:(.*)\n" $lines match foundContentType]
    set_exit_msg "probe fail : can't find \'Content-Type\' header"
    exit 30002
# Content-type value does not contain the requested string
if { ![ regexp "$expectFileType" $foundContentType]  } {
    set_exit_msg "probe fail : expect content-type \'$expectFileType\', but got
\'$foundContentType\'"
    exit 30002
# Indicate probe success with exit code 30001
set_exit_msg "probe success"
exit 30001
Related Content
