Cisco asa 5510 web vpn homepage customization
Sep 14th, 2010
hello, weare using ASA with clientless users with a customized portal, usint the post command on bookmarks, we can have "credentiales passthru" from the login page (asa is connected to AD domain) using post parameters.There are a group that needs the home page using the company intranet page (using the option homepage URL in the customization or the internal group policy.The problem is that is working ok but we cant use post commands, the user needs to login again, any idea?, using asdm 6.2(5) with ASA 8.2(2)
m.schlienger Tue, 12/07/2010 - 23:07
I have same kind of request (except on asa 5505, asa8.3, asdm6.3). We have successfully configured Exchange 2007 OWA Access with "SSO" thanks to POST bookmark.
But we still have to use a bookmark, while it would be so elegant to have a straight redirection to OWA after logging in. Technically it should not be a problem, it is just a feature that seems not to appear with current versions.  Let me know if you found any kind of solution.
alig.norbert Mon, 12/27/2010 - 13:20
Could you please post the POST Bookmark with OWA? I'm trying to get it done at a customer's ASA...
