1841 VPN Problem
Sep 14th, 2010
Hi All
I've just remoted into an 1841 router to set up a VPN but found to my surprise no commands available to set it up, ie. crypto isakmo policy n and the following  subsequent commands are not available. Checking the flash there seems to be all the files I presumed would enable me to create the tunnel.. Any advice would be greatly appreciated.
Regards  pgatt62
Rtr#sh flash:
-#- --length-- -----date/time------ path
1     14097560 Nov 02 2009 14:04:04 +00:00 c1841-broadband-mz.124-1c.bin
2         1821 Oct 30 2006 18:55:20 +00:00 sdmconfig-18xx.cfg
3      4734464 Oct 30 2006 18:56:00 +00:00 sdm.tar
4       833024 Oct 30 2006 18:56:24 +00:00 es.tar
5      1052160 Oct 30 2006 18:56:50 +00:00 common.tar
6         1038 Oct 30 2006 18:57:14 +00:00 home.shtml
7       102400 Oct 30 2006 18:57:38 +00:00 home.tar
8       491213 Oct 30 2006 18:58:04 +00:00 128MB.sdf
9      1684577 Oct 30 2006 18:58:46 +00:00 securedesktop-ios-3.1.1.27-k9.pkg
10      398305 Oct 30 2006 18:59:26 +00:00 sslclient-win-1.1.0.154.pkg
11        2096 Sep 15 2009 22:48:16 +01:00 pre_autosec.cfg
12        1588 Jul 17 2010 21:29:00 +01:00 .ios_resil.dat
_Rtr(config)#c?
call             call-history-mib  carrier-id  cdp
chat-script      class-map         clock       cns
config-register  configuration     connect     control-plane
Jennifer Halim Tue, 09/14/2010 - 06:06
  • Cisco Employee,
You would need the advance security feature set for VPN configuration.
At the moment, you are running "broadband" feature set only.
