CVP 7.0(2) not creating correct string to send to VXML Server
Sep 14th, 2010
When running CVP 7.0(2), has anyone run into an issue with CVP still attaching the [locale]/[app_media_lib] when setting app_media_lib = ".." in the ICM script?
http://1.1.1.1:7000/CVP/en-us/../Server?application=HelloWorld resulted in a bad fetch.
I was able to find a bug that says the workaround is to use "...", but that did not work.  Below are the bug details.  Any thoughts?
How to configure app_media_lib for VXML Server apps in incorrect
Symptom:
Integrating a Call Studio script with Unified ICME scripts fails
Conditions:
Call returns the following error on the gateway
Loading fail with url (http://{VXML-Server-IP}:7000/CVP/en-us/.../Server?callid={callid}&application={Application Name)
Workaround:
Make sure the app_media_lib ECC Variable is set to "..."
Nathan
gall00004 Tue, 09/14/2010 - 11:38
Geoff,
I took advice you had posted on a previous topic and went through and set all the ECC variables to recommended lengths, added in one more ECC (user.microapp.play_data) and then rebooted the CVP PG.  It's strange to think that I could play wav's from the media server, but not execute VXML if the ICM states were funky and the restart was actually what corrected it.  So I'm leaning towards something I did with the ECC's although not exactly sure what part, but all is working now.
