VLAN tagging help
Hey all,
I have a network in which we have to use VLAN tagging to trunk the two seperate networks over 1 ethernet connection. Can you recommend this setup?
There are two seperate subnets, the end devices are not VLAN capable. So im thinking: Uplink ports between the two switches, tagged 802.1Q, the end device;s port will be a member of the appropriate vlan, but untagged. I have attached a picture of a similar setup. Let me know what you guys think.
Thanks!!!
Gideon
Julio Garcia Tue, 09/14/2010 - 07:34
  • Bronze, 100 points or more
Gideon,
there is a little bit of a problem with this
what if people in vlan 1 want to communicate with people on Vlan 2 ?
are you doing any routing? and what are the default gateway of the devices in vlan 1 and 2 ?
Rob,
The goal is to actually keep the two vlans seperate so they cannot communicate. I only have one FastE connection for the backbone. So it would seem vlan tagging is the only option.  The default gateway for one network is 10.1.1.1 (gateway router) which will be connected to the main switch. The other vlan scheme is yet to be determined.
glen.grant Tue, 09/14/2010 - 07:46
  • Purple, 4500 points or more
  If those are layer 3 switches and one of them is doing the routing what you propose should work ok .
