Stack question
Sep 14th, 2010
I have a stack of 4 3750G which all have 24 ports.  I need to buy another switch as we are running out of ports can i add a 48 port version of the switch, or do they all have to be the same?
Collin Clark Tue, 09/14/2010 - 09:05
  • Purple, 4500 points or more
Hi Andy-
You can add the 48 port switch. You need to make sure that it is the same major IOS version as your 24 port switches. Here's a helpful link.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstack.html
I also suggest that you provision it so nothing gets messed up. The directions on how to do that are in the link above.
Hope it helps.
Andy White Tue, 09/14/2010 - 09:13
I can't access that site, I log in but says I don't have permission
Here is my current spec on the switches in the stack, what am I looking for?  I guess I need a WS-C3750G-48T-S and use the firmware c3750-ipbase-mz.122-53.SE.bin :
#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(53)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 13-Dec-09 16:25 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02A00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
ISCSI-3750-A uptime is 32 weeks, 3 days, 8 hours, 40 minutes
System restarted at 07:29:54 utc Sat Jan 30 2010
System image file is "flash:c3750-ipbase-mz.122-53.SE/c3750-ipbase-mz.122-53.SE.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision N0) with 131072K bytes of memory.
Processor board ID FDO1240Z05S
Last reset from power-on
8 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       :
Motherboard assembly number     :
Power supply part number        :
Motherboard serial number       :
Power supply serial number      :
Model revision number           : N0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24T-S
System serial number            :
Top Assembly Part Number        :
Top Assembly Revision Number    : A0
Version ID                      : V06
CLEI Code Number                :
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 24    WS-C3750G-24T      12.2(53)SE            C3750-IPBASE-M
     2 24    WS-C3750G-24T      12.2(53)SE            C3750-IPBASE-M
Collin Clark Tue, 09/14/2010 - 12:03
Sorry about the URL. Cisco's site randomly logs me in and out. When I went to get the URL I looked and it did not have me logged in so I assumed it never logged me in, but I guess it did.
Andy White Wed, 09/15/2010 - 03:40
Thanks, great doc.  Basically as log as provision them properly like I have before I should be fine I guess.  All our switches are WS-C3750G-24T-S so if I get the WS-C3750G-48T-S and use the same IOS that they are using which is 12.2(53)SE - C3750-IPBASE-M?
one of the stacks:
Thanks in advance for your advise.
