PIX to ASA conduit
Sep 14th, 2010
I am working on a project in which i have to remove a PIX 515E
and have to connect an ASA 5510, i have copied all the commands from PIX to ASA except the conduit commands
following are the examples of the conduit commands i have
conduit permit tcp object-group HistoryModule_ref object-group HistoryModule-Ports object-group Mixit-HistoryModule
conduit permit tcp object-group Weed-MOMs_ref object-group RTS-Ports object-group Weed-MOM-INET
conduit permit tcp object-group Weed-Fix_ref object-group FIX-Production-Ports object-group Weed-FIX-INET
Please let me know how to convert them and apply it on the ASA.
Federico Coto F... Tue, 09/14/2010 - 08:30
It's been a long time since I last saw conduits.
I remember there were inverse to ACLs (you first specify the destination and then the source).
So, it depends on your configuration but you need to revert the order, i.e.
If you have a conduit like this:
Most likely will be like this:
access-list permit tcp object-group Mixit-HistoryModule object-group HistoryModule_ref object-group HistoryModule-Ports
Again,
I'm assuming that:
object-group HistoryModule_ref and
are the destination IPs and ports
and that
is the source.
Federico.
