836 router - startup-config is not copied to running-config on startup
Sep 14th, 2010
Dear Cisco Administrators,
I recently purchased a 836 router with IOS (Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2))
After a successful --- System Configuration Dialog --- setup and my confirmation to write the configuration to NVRAM and a reboot of the device, the System Configuration Dialog is started again. Howto tell the device to copy the present startup-config to running-config on boot?
My settings are present in the startup-config, they just are not copied. After manually do so, everything is fine.
Any help is greatly appreciated
Stefan
Jon Marshall Tue, 09/14/2010 - 12:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Stefan
Stefan
It sounds like your config register is wrong. Can you post the output of "sh version".
Jon
bauerstefan Tue, 09/14/2010 - 12:49
Jon,
awesome! It was a problem with the config register. The one i bought the device from set it to a wrong value. I changed it back to
0x2102 and the problem was solved! Thanks for helping.
Jon Marshall Tue, 09/14/2010 - 13:03
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Stefan
No problem, glad to have helped.
Jon
