TCP/UDP port number instead of name
Answered Question
Sep 14th, 2010
Hi All,
Is there way to display the a standard TCP/UDP  port number(s) defined in a ASA/PIX?
for example, when creating an object-group
FWNAME(config-service)# service-object tcp ?
dual-service-object-group mode commands/options:
  <0-65535>        Enter port number (0 - 65535)
  aol
  bgp
  chargen
  cifs
  citrix-ica
  cmd
  ctiqbe
  daytime
  discard
  domain
  echo
  eq               Port equal to operator
  exec
  finger
  ftp
  ftp-data
  gopher
  gt               Port greater than operator
  h323
  hostname
  http
  https
How do i find out the numerical values tied to those names?
Thanks in advance
Correct Answer by Marcin Latosiewicz about 6 years 6 months ago
Hi all,
In short, no.
Those are names for well known ports. Configuration guide is always a good place to start if you don't know which one is which.
Have a look here:
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/ref_ports.html#wp1007738
Marcin
Overall Rating: 5 (1 ratings)
