Backup of LMS 2.6 SP1 database fails with error (686)
Sep 14th, 2010
I am trying to backup LMS 2.6 SP1 database on Windows 2003 server prior to performing a local upgrade to LMS v.3.2. But I get the error below. I saw another article related to this error code https://supportforums.cisco.com/message/652601?tstart=8 So I already verified that the server does not have any other cygwin applications installed and that the registry value key is empty.
Per LMS 3.2 upgrade instructions, I upgraded DFM from 2.0.10 to 2.0.11 because documentation say it would cause backup to fail. After successfully upgrading DFM I used the wapper.pl script to run a CLI backup of the database but I am still getting the error below. I could try to perform an inline upgrade from the DVD. I believe all the application data for the other modules may migrate successfully and DFM data will probably fail to migrate. Is this my only option now?
thanks,
John
Backup to 'c:/cwdbbackup/scheduled' started at: [Mon Sep 13 22:00:00 2010]
Archiving the contents of the following directories into c:/cwdbbackup/scheduled\137\campus\filebackup.tar
d:/CSCOpx/campus/etc/cwsi\DeviceDiscovery.properties
d:/CSCOpx/campus/etc/cwsi\ANIServer.properties
d:/CSCOpx/campus/etc/cwsi\discoverysnmp.conf
d:/CSCOpx/campus/etc/cwsi\datacollectionsnmp.conf
d:/CSCOpx/campus/etc/cwsi\Snmpv3EngineParam.txt
d:/CSCOpx/campus/etc/cwsi\UTSnmpv3EngineParam.txt
d:/CSCOpx/campus/etc/cwsi/users
d:/CSCOpx/campus/etc/cwsi/archives
d:/CSCOpx/campus/etc/users
d:/CSCOpx/campus/etc/cwsi/ReportArchives
d:/CSCOpx/htdocs/campus/maps
/cygdrive/d/CSCOpx/bin/tar: Removing leading `/' from member names
Archiving the contents of the following directories into c:/cwdbbackup/scheduled\137\cmf\filebackup.tar
d:/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet\cwpass
d:/CSCOpx/lib/classpath\sso.properties
d:/CSCOpx/lib/classpath/com/cisco/nm/dcr\dcr.ini
d:/CSCOpx/MDC/Apache/conf/ssl
d:/CSCOpx/www/classpath/com/cisco/nm/cmf/security\secret.dat
d:/CSCOpx/www/classpath/com/cisco/nm/cmf/security/jaas\JaasConfig.xml
d:/CSCOpx/www/classpath/com/cisco/nm/xms/psu/maps
d:/CSCOpx/objects/data/cmf/cmic/registered-templates
d:/CSCOpx/objects/data/cmf/cmic\cmic.xsd
d:/CSCOpx/conf\logstat.conf
d:/CSCOpx/etc/licenses
d:/CSCOpx/MDC/etc\regdaemon.xml
d:/CSCOpx/lib/classpath\comUser.dat
d:/CSCOpx/lib/classpath\proxy.properties
d:/CSCOpx/conf\signFile
Archiving the contents of the following directories into c:/cwdbbackup/scheduled\137\dfm\filebackup.tar
d:/CSCOpx/objects/smarts/conf
d:/CSCOpx/objects/smarts/local/conf
d:/CSCOpx/objects/smarts/local/repos
d:/CSCOpx/objects/smarts/local/logs
d:/CSCOpx/setup\dfm.info
/cygdrive/d/CSCOpx/bin/tar: /CSCOpx/objects/smarts/local/logs/DFM.log: file changed as we read it
/cygdrive/d/CSCOpx/bin/tar: Error exit delayed from previous errors
ERROR(686): Cannot create or back up tar file. Backup cancelled. Verify that you have write-access to this directory.
Backup failed: 2010/09/13 22:24:26
CORRECTION:
At first it appeared that the backup was failing. But the DFM upgrade actually did fix this problem. After running backup again it did finally succeed with RC 0. Thanks
