Encryption Voice Call CCM 4.1
Sep 14th, 2010
What parameters I have to configure to enable encriptaion of calls in the Call Manager Server, version 4.1?
Overall Rating: 4 (1 ratings)
Aaron Harrison Tue, 09/14/2010 - 11:41
lots of steps, which vary depending which products (gateways/phones etc) you have. Read the security guide for starters:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/4_1_3/sec413.html
While you are reading that, you also need to order 2 KEY-CCM-ADMIN-K9 security keys to enable the cluster for 'mixed mode' security. No keys, no encryption.
Aaron
Please rate helpful posts...
ricardorojas123 Tue, 09/14/2010 - 13:38
To encrypt the calls between two IP phones just enough to set the value Device Security Mode to Encrypted?
Jaime Valencia Tue, 09/14/2010 - 17:15
After you go thru the whole process of creating the CTL file and using the 2 USB keys, getting the file to the phones... yes.
If you mean if you can just go right now and try to change it without the USB tokens and creating the CTL file, then no.
The whole process is outlined in the link Aaron posted, have you gone thru it?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
