CME Web Gui Error CME Login Failed
Sep 14th, 2010
When I try to log into  CUE 3.2 web interface  http://10.1.10.1/Web/cme/LayoutAction.do?submitType=INIT&page=displayDN
in system paramater I got an error message
"Error: Unable to login as administrator to the Cisco CallManagerExpresse at site local"
the loggin is working properly but not for the Extensions, Phones and System Parameters
Router    : CISCO3845
Configure > Extensions
Site Name:local
Error: Unable to login as administrator to the Cisco CallManagerExpress at site 'local'.
Details: CME login failed
Overall Rating: 5 (1 ratings)
Walter Solano Wed, 09/15/2010 - 07:14
  • Gold, 750 points or more
Yanice please check if you have added the "ip http path flash:/gui" command to your configuration, also check if you have connectivity to both CME and CUE if you dont you can use static routing in the PC to be able to reach them.
Please rate this post if was helpful
Walter Solano
Yacine Hidouche Mon, 09/20/2010 - 07:28
Hi Walter,
It is now working pefectly, all I did was,
no ip http path flash:/gui
Thank you very much for your help
Yacine
Walter Solano Wed, 09/22/2010 - 05:17
Hello Tacine,
I am happy to hear that everything is working now and I was able to helo you .
Thanks.
omaryusoff Wed, 03/19/2014 - 06:59
Hello Walter,
I have the same problem and even after
ip http path flash:/gui,
the problem is still not resolved.
Can you help me?
Thanks in advance
